96 130amp alternator
RE: 96 130amp alternator
As far as I know, you may need to stretch out the wiring from the harness to the alternator, but that should be it. I also remember something about the rear case being slightly oversized which may require some slight filing or grinding at an interference point to the intake housing?
FWIW, I installed a new 160amp unit from PAPerformance designed for the 'stangs and it fit with no alteration.
What does our cars have on them now?(93s-95s)
OEM was 120 amp Mitsubishi units, supposedly "non-rebuildable"?
yes it does. But is a very small amount. You will probably not notice a difference at the track since going from 120-130 is almoust nothing.
Theoretically, HP depends solely upon the electrical load and RPM. But in the real world you may find marginal differences in HP requirements solely due to efficiency ratings. Probably not enough to worry about, especially on a stock vehicle.
Driller,
This 160amp you got, would it be the same for a 97 mark? if so do you mind if I ask how much and where I can go to order it.
I thought it was a 160 amps. This is what I got...
http://www.pa-performance.com/images/items/14.jpg
4G Alternator for 4.6L DOHC Ford
Alternator Kits
Part # 1988 $259.00 Each
1996 - 2002 DOHC Cobra / Bullitt
130 AMP Alternator Kit
This is a very popular replacement where slightly increased capacity is needed. This unit will increase the charging capacity at all RPM Ranges with NO modifications.
· Common on Ford DOHC Applications
· This unit is a direct replacement with NO modifications
· 80 amps at idle (950 rpm)
· 145 amps maximum (3000 engine rpm)
· The stock belt can be used on original equipment vehicles
· Actual Alternator Weight is 15.2 lbs
· All units are 100% NEW and come complete with internal voltage regulator and pulley
http://www.pa-performance.com/display.asp?sku=14
For some reason I thought it was this...
http://www.pa-performance.com/images/items/131.jpg
130 (Optional 200 AMP) 3G Alternator
Alternator Kits
Part # 1904
$199.00 Each
· 160 amps maximum (3000 rpm)
http://www.pa-performance.com/displ...Num@6,cat@Alternator+Kits,backNum@1,nextNum@2
I apologize for my confusion. Regardless, my rebuilt alternator only put out 20 amps at idle. Turning everything on max I recorded over 55 amps at idle with the new one.
There were no fitment issues. I did order a 4 gauge power wire kit with 200 amp fuse along with the alternator. I ran it along with the stock wiring and hooked up to the 12V power lug on the engine compartment fuse box.
I emailed the company and they said the H.O. $199 alternator will not fit on a cobra or mark viii. Even though the picture is exactly the same for both, they told me to order the 4G.
