should i bother or just use new stock bolts when i put on my new heads?
R ryanharrington Registered Apr 14, 2006 #1 should i bother or just use new stock bolts when i put on my new heads?
M M8SHOSCGUY Registered Apr 16, 2006 #2 RE: head studs? If you use studs, you'll have to drop or lift the engine to get the heads on/off. Studs are stronger and the nuts can be reused, new head bolts are about $50. Those are the trades.. bolts seem to work fine for most applications. mark
P Ponyfreak Registered Apr 18, 2006 #3 RE: head studs? [div class="dcquote"][strong]Quote[/strong] If you use studs, you'll have to drop or lift the engine to get the heads on/off. [/div] This is an untrue statement. The studs can be removed first while in car and then the head will come off just like it does with the bolts.
