OK, on the way home last night I noticed that my battery light would come on when I was stopped with the car in gear. If I put it in park or nuetral it would turn off, and if I tapped the gas just a little it would turn off. After a little while I started getting an electrical smell through the a/c vents. The smell lasted for about a minute, then just went away and the battery light stopped coming on. At no point did the check charging system warning pop up and when I ran the system check it said everything was fine.
Could this be as early sign of a failing alternator? Or is this just some kind of weird anomoly? The car's a '95 with 120k miles and I believe it still has it's original alt.
