Replaced Blend Door Actuator
Neontail97
Replaced my blend door actuator last night. I printed out the instructions by Alexander and followed them to a T. I dreaded this job all summer until I finally had to tackle it due to cold weather. It was really fairly simple with the instructions. Without them it would be a nightmare.
I can't say enough about the "GREAT" job Alexander did on the invaluable instructions. It only took me 2.5 hours. I also performed the reinforcement of the actuator arm which worked well.
Anyone with reasonable mechanic skills should not be afraid to tackle this job.
Thanks again Alex!
RE: Replaced Blend Door Actuator
You are welcome. I am glad the instructions were helpful.
So far my reinforced blender door arm is holding up well after more than two years of service.
Alexander
President
Lincolns of Distinction
Here it is below, there are a few articles about it. An easier reinforcement instead of the wire is to put a compression fitting piece on it.
Here's a link that shows the workings of the blend door.
