I just bought a 95 LSC and need to find/replace the flasher unit. Because it does not work, there is no noise for me to follow to locate it. Can anyone direct me to the location of the flasher, please?
Check THIS thread.... BTW, the search function is your friend:
From my manual:
Turn Signal and Hazard Lamps
The turn signal system consists of:
l multi-function switch (13K359).
l steering column/ignition/lighting control module.
l redundant directional flashers in the outside rear view mirrors.
l turn signal bulbs and circuitry.
The multi-function switch is an integrated switch design. When the multi-function switch is activated in either direction, or the hazard switch is engaged, a request is made from the multi-function switch to the steering column/ignition/lighting control module to flash the appropriate turn signal lamps, mirror indicators and turn signal indicators in the instrument cluster. The instrument cluster is equipped with a relay to provide an audible click anytime one or both of the indicators illuminates.
