Alignment Question!!!!!
NickT88LSC
I am getting ready to align my car and was wondering what Height I should use when performing the alignment??? What I mean is should I use the lowered height like when you turn your car off and get out the car lowers, or the height as when you start your car and it raises then turn off the suspension switch and use that????
My cars sensors are set to the lowest ride height that they could in the adjustment.
Thamks,
Nick
RE: Alignment Question!!!!!
Align it at parked height. I believe that's the same as the highway height.
True. Make sure it is a 4 wheel alignment as well.
Ditto the above posts as these vehiciles are twitchy for vibs (tires, wheel balance, wheel index, rotors, drive shafts, bushings and alignment). They need attention to detail. Iwould start at the upper ball joints as this is the least expensive and do able
