Progress report: Got some things done to the car, feel like sharing.
opalescent 96
I found a Thunderbird SC solid rear sway bar in the junkyard for $15. (Stock Mark sway bar is on the bottom).
I installed the B&M transmission oil cooler that was featured in the tech section. Looks nice!
...and I just finished the jmod. That was a lot of work! Not just the installation but all the research and collecting the parts.
I did the 300-450hp drill bit sizes. New style 1-2 accumulator with both springs, new lower. New 2-3 accumulator with no spring. I also got the improved design Sonnax pressure modulator valve. I ended up using almost 13 quarts of Mercon V.
Next on the list is a radiator flush and new thermostat because she runs hotter then I would like and the fan seems to be working properly though I wish it would click on a little sooner.
