Page 10 of 10 FirstFirst ... 8910
Results 91 to 95 of 95
Thread: 95 Mark VIII Convertible
  1. #91
    Apr 2005
    North Saint Paul, MN
    6,624
    3,308
    Those CE shifters are the way to go. They feel so much better in the hand than the leather ones.
    What did you end up with for a Head Unit? Any additional work on speakers, etc?
    Mike Martin
    1997 Mark VIII LSC 5.0
    2001 Dodge Dakota
  2. #92
    Jul 2009
    355
    15
    The shifter feels so much better. Now I need a wood steering wheel.
    I went with the pioneer nex 6200 in the vert. It has the little detachable security tab on the left, and antiglare screen which is not great in direct sunlight. I'm still rocking the original speakers and they sound great compared to the stock unit. Might just throw a sub in it and be done, but I do have more plans for the audio. Looking at a few other upgrades before the stereo is finished.
    MR. HYDE
    The Build
  3. #93
    Jul 2009
    355
    15
    Had to replace the Air Compressor Relay Connector and Wire up past the 90° bend into the harness. Was down for about 5 weeks. Jeremi told me exactly what the problem was on day 1. At first I just tried a new relay, didn't work. Tried prying the tabs out in the connector to make better contact. Didn't work. Got a new connector, cut old connector off close to the connector to maximize wire length in case of whatever. I soldered and heat shrunk the connections. Worked. Was excited. I changed the oil, put back on the bumper cover, bundled everything up. Turned on the car, front dropped, compressor wouldn't come on. Had to take the whole bumper off again since the wire harness is from a gen ii and there's no way to get to that connector. I was talking with Bruce about an hour earlier. He said (too late, after I already soldered the first time) that he recalled the problem occurring further up the wire where it took the hard 90 into the harness. I squeezed the harness and the compressor kicked on. FML. So i proceed to cut open the wire harness as much as I needed. Recut the wires much higher past the 90. Re-soldered the new harness, and all is good. Tested multiple times before reassembly. 20171021_191029.jpg
    The original harness
    The first attempt cutting right at the harness. I didn't take a pic of the final final connection, but it was a lot more even.
    MR. HYDE
    The Build
  4. #94
    May 2005
    Grosse Ile, Michigan
    6,386
    1,081
    Good job!
    I've had to do this a few times before, on various Marks, replacing the connector, and/or replacing a wire going to it.
    Usually just cutting the wire back until it is clean copper works, but sometimes I've just run a new wire all the way back to the module.
    I don't know why these fail so often, the ABS and secondary air injection pumps on some years, use these same relays, connectors and wires, but those don't seem to fail as often.
    My first guess is low quality lightweight wires and the fact that air ride relay is used more often.
    Bill
    1994 Deep Jewel Green 183,142 miles
    1997 White LSC 135k miles
    1998 White Collectors Edition 175k
    1994 Black (#2) 100k miles
    1993 Deep Jewel Green Convertible
  5. #95
    Jul 2009
    355
    15
    I would guess the usage, heat, extreme vibration, and the tight radius at the 90 into the connector. Typically want about 10x the diameter of the wire for a bend radius for optimal cable performance.
    MR. HYDE
    The Build
  1. 94 Mark VIII Convertible Progress Thread
    By k9t8m in forum General Lincoln Discussion
    Last Post: 12-24-2010, 12:29 PM
  2. 1994 Lincoln Mark VIII Convertible
    By k9t8m in forum Cars (Buy/Sell/Trade)
    Last Post: 08-06-2010, 09:35 PM
  3. Mark VIII Convertible Pictures
    By k9t8m in forum Members Rides
    Last Post: 08-04-2010, 08:52 AM
  4. Prototype Mark VIII Convertible
    By billcu in forum General Lincoln Discussion
    Last Post: 01-17-2008, 08:04 PM
