AnthraxBird
bahaha, screw the seat... lets see some more pics =P
Oh please, it was snowing. Our girls here actually make it into the Hooters calendar.![]()
for hooters girls quite a few of them have some seriously busted faces. then again it is called hooters and not faces, so if you dont look at the face all of them look hot!
Those are some nice shots of seats.
Sorry, here are some ugly ones. The clips are pretty easy if you can get to them. You need to press the cushion down to release the tension on them then just move them off the rail.
Here's a photo of the bottom of a gen 1:
The seatback will hold the cushion down in the back but you should be able to move the bottom cushion out of the way enough to get in there.
There's also a fuse on the seat track. It's on the top of the seat track assembly and beneath the actual seat. I think the seat cushion and stuff need to come off first to be able to get to the fuse, IIRC.
Good luck
