Need some help !
shospeed
Well sence my Mark is on the garage i've desided to try to get all the little gliches fixed before i put it back on the road!
I'm having issues with the driver side seat and the rear view morrors, at time they work and at times they wont work.
When i try to move the seat nothing happends at times and some times out of no were I'll try it and it will work same thing with the rear view mirrors I've even turned the rear view mirrors of when you go in reverse cause they wount go back to the position that they were before.
I've checked all the fuses on the side of the door and under the hood, I checked under the seat and there is no visible cable out of place or anything like that. I also have some a/c problems not blowing hot air truw but lets fix ONE issue at a time.:(
Do yall know what can be causing this?
or has anybody encounter this problem before?
Thanks guys in advanced yall have been of allot of help before !!!;)
No, you can't unplug it, but it may help to reseat the harness connections. Besides pages and pages of diagnostics, the best bet is to test with a known working unit.
