Page 14 of 15 FirstFirst ... 412131415 LastLast
Results 131 to 140 of 145
Thread: 1993 Mark VIII convertible progress
  1. #131
    May 2005
    Grosse Ile, Michigan
    6,444
    1,122
    Thanks Kirk.
    I finally made it to the other side with the first row.
    I can't believe it lined up perfectly with the original stitches.
    I thought for sure I'd have to do some "adjusting".
    Enough of this crap, I'm off to the cruise!
    Attached Images Attached Images
    Bill
    1994 Deep Jewel Green 183,142 miles
    1997 White LSC 135k miles
    1998 White Collectors Edition 175k
    1994 Black (#2) 100k miles
    1993 Deep Jewel Green Convertible
  2. The Following User Says Thank You to billcu For This Useful Post:
    Ford nut (06-30-2017)
  3. #132
    May 2005
    6,444
    1,122
    I finished one row of the double stitches, I still need to finish the other row, but I might get caught in rain this weekend, so I thought I'd try checking the stitches and rest of the top for leaks now.
    The seal for the top by the windshield was mostly missing, you can see the orange adhesive and white caulk here and there, with some rubber pieces by the A pillar area.
    I removed the rubber pieces and most of the caulk and stuck on a strip of closed cell foam seal I found for pick up truck cap mounting. I put some paper towels around all the sealing areas inside the top and sprayed the outside of the top with water to check for leaks.
    It wasn't too bad, all the paper towels were dry except at the A pillar areas on both sides at a spot that I didn't seal yet. There were no leaks at my stitches.
    Here's some photos, I don't have the after photo of the new seal yet, as I'm leaving the top up and clamped to make sure the adhesive sticks.
    Bill
  4. The Following 2 Users Say Thank You to billcu For This Useful Post:
    Lownslowlsc (06-30-2017),tixer (06-30-2017)
  5. #133
    Apr 2005
    North Saint Paul, MN
    6,695
    3,388
    I think I'm beginning to understand why people always claim old convertible tops are so "finicky." Age and neglect, leading to quick fixes that don't actually work.
    You really saved this one, Bill. Keep up the good work.
    Mike Martin
    1997 Mark VIII LSC 5.0
    2001 Dodge Dakota
  6. The Following 2 Users Say Thank You to tixer For This Useful Post:
    billcu (07-01-2017),Ford nut (06-30-2017)
  7. #134
    Aug 2007
    Farmington, Mn
    854
    214
    Very nice. I could see how you wouldn't want to get caught in the rain how it was, and watch as it slowly gets more damage.
  8. The Following User Says Thank You to Ford nut For This Useful Post:
    billcu (07-01-2017)
  9. #135
    May 2005
    6,444
    1,122
    Thanks guys.
    Quote Originally Posted by tixer View Post
    That's why they call them 'Ragtops'.
    Bill
  10. #136
    Sep 2003
    Windsor, Ca, U.S.A.
    2,581
    110
    if money grew on trees, you could just roll it in to any upholstery shop and they'd stitch you a nice new one. But it would be at least $1200 and if you went with a nice chestnut canvas color OOOOHHHHH boy
    lookin mighty fine there Bill...just keep track of your hours/time so you can put a value on it so when I come in to a large sum of cash I can make you an offer you cannot refuse
  11. The Following User Says Thank You to BlackIceLSC For This Useful Post:
    billcu (07-04-2017)
  12. #137
    May 2005
    6,444
    1,122
    Thanks again guys.
    Here's some shots of the seals I put on, along with a before shot for comparison. The first one was where the top meets the top of the windshield area,
    I also added 2 pieces that weren't there before, there was a big gap where the top meets the windshield vertically. I circled the seal strips I put there, one on each side. There's a shot of the top not latched, then latched.
    Bill
  13. The Following 2 Users Say Thank You to billcu For This Useful Post:
    BlackIceLSC (07-22-2017),Ford nut (07-18-2017)
  14. #138
    Sep 2003
    Windsor, Ca, U.S.A.
    2,581
    110
    looks perfect to me...nice work Bill
  15. The Following User Says Thank You to BlackIceLSC For This Useful Post:
    billcu (07-22-2017)
  16. #139
    May 2005
    6,444
    1,122
    I haven't done much work on the car lately, I've been driving it a lot, it's been running great.
    I thought I had a differential leak but it turned out to be from the hydraulic top pump in the trunk. The fill plug had popped out at some point, and leaked some fluid through the pump screw holes, down onto the ABS sensor on the diff.
    Bill
  17. #140
    May 2005
    6,444
    1,122
    I finally replaced the rear shock mounts today.
    It still had the 93/94 shock actuators on the original shocks.
    I kept the original shocks, but I didn't put the actuators back on.
    Here's a pic of the mounts and actuators.
    No more clunking.
    Bill
  18. The Following User Says Thank You to billcu For This Useful Post:
    steve (10-24-2017)
  1. 95 Mark VIII Convertible
    By warden in forum Members Rides
    Last Post: 10-22-2017, 10:53 AM
  2. 94 Mark VIII Convertible Progress Thread
    By k9t8m in forum General Lincoln Discussion
    Last Post: 12-24-2010, 12:29 PM
  3. Mark VIII Convertible Pictures
    By k9t8m in forum Members Rides
    Last Post: 08-04-2010, 08:52 AM
  4. Prototype Mark VIII Convertible
    By billcu in forum General Lincoln Discussion
    Last Post: 01-17-2008, 08:04 PM
