Tremec 6 speed install in work. Has anyone done this before. 98 mark. I'm using the clutch pedal assy. from a supercoupe. having the drive shaft mfg. we used the existing trans support. Everything seems fine so far. Shifter location is falling right in the sweet spot. I'll have pics. later and note any severe problems. We may have a PCM harness made and move the PCM behind the rear seat. That will be much less work than spliceing all of the wireing. Most clearance problems have been minor so far. I also plan on building a forged engine and adding Twin turbos to the shark. More to follow.
