HEEEEELP!!! SPark plug related.
Misanthropy
Information Junkie
Just got done replacing the driver side cam/valve cover seals and on the last cylinder while pulling the plug it was ... well bad threads, but very minor. I have a full gear wrench tap and die set... 0 experience using it.... Need to know what tap to use to just clean the threads up.... Obviously its a long shot with aluminum.
I have watched a few videos and even if its just a thread cleaning process I will be sure to get any shavings out of the cylinder.
I will reference online and my 93 manual for the pitch/diameter, but I would really appreciate anyone throwing it at me so if I Fail at finding the information I can come back here.
As always, Thanks !!!!
Third valve cover job. Still hate doing that. Although I read up on it and decided to loosen the motor mounts this time instead of take the master cylinder out. Worked great. The hardest part was that damn dip stick bolt re-insertion and removing it initially.
