Save on Replacement Air Springs and Shocks
Results 1 to 9 of 9
Thread: rear sway bar end links and bushings
    3,800
    41
    Default rear sway bar end links and bushings
    What are our options for replacement rear sway bar end links and bushings if we are using an Adco bar? The original adco links bent.
    Mar 2008
    Central MO
    1,208
    43
    my addco has bent every end link i've put in it so far.
    so i'll follow this.
    1996 Lincoln Mark VIII LSC Opal Opalescent on grey
    1995 Lincoln Mark VIII LSC Indigo Lights on black
    2002 Ford Focus SVT Sonic Blue on black
  3. #3
    Jan 2007
    Wild and Wonderful
    14,364
    1,043
  4. #4
    Sep 2003
    Windsor, Ca, U.S.A.
    2,508
    77
    I had to shim the body/chassis mount brackets to stop from bending end links on my addco 1-1/4" bar.
    IF the car is lowered, you have to cut the end link sleeves accordingly.
    also, make sure you tighten them with the car on the ground to prevent the bar being in a bind:
  5. #5
    Jan 2007
    Wild and Wonderful
    14,364
    1,043
    I sent an email to PowerGrid and they no longer have anything to offer that would fit the Mark VIII.
    I'm looking into either some other adjustable links or fabricating my own with some heim joints.
  6. #6
    3,800
    41
    we still have a DLF sway bar bushing kit to work with sharon's sway bar. It replicates what BlackIce describes. I am sure JP had a DLF kit on one of his cars. Doug sold a kit that included a Energy suspension bar busing, stainless steel shims, and stainless bolts. Juts need new links.
  7. #7
    Jan 2007
    Wild and Wonderful
    14,364
    1,043
    Quote Originally Posted by beerdog View Post
    Just need new links.
    Are the top/bottom link grommets still good? You could just get a new long bolt and re-use the sleeve and grommets.
    I'm not sure what grade the fasteners in the Addco links were but I would suggest a Grade 8 bolt for a high yield strength.
    Energy Suspension has a complete line of universal end links but I noted their bolts were Grade 5.
  8. #8
    3,800
    41
    It has been a while since I changed these. Is the link just a long bolt?
  9. #9
    Jan 2007
    Wild and Wonderful
    14,364
    1,043
    Most aftermarket ones, yes.
  1. sway bar end links
    By thegr81 in forum Brakes / Suspension / Steering
    Last Post: 02-07-2015, 02:05 AM
  2. 1997 Lincoln Mark VIII rear sway bar end links
    By tonybrooklyn in forum Brakes / Suspension / Steering
    Last Post: 08-31-2012, 07:56 PM
  3. Energy suspension modified rear sway bar bushings/brackets
    By calisonic in forum Brakes / Suspension / Steering
    Last Post: 11-13-2011, 06:39 PM
  4. Sway Bar Links and Rear Shocks
    By driller in forum Brakes / Suspension / Steering
    Last Post: 05-06-2009, 02:19 AM
  5. Rear shocks and sway bar bushings
    By ggfrank21 in forum Brakes / Suspension / Steering
    Last Post: 03-27-2008, 06:09 PM
