Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Track time!
    Jan 2007
    Wild and Wonderful
    14,589
    1,142
    Default Track time!
    Not much to brag about, but I had an opportunity to finally get to the track on short notice.
    It was a rather warm summer day, so it was not the best of times and I had so little preparation, I hadn't prepared well enough to bring my tuning stuff with me so all we got to do was make a few passes and practice.
    It started out rather lacking with a 1.952 sixty foot and the 1/4 mile ET was 12.923 @ 107.11. We followed that with a 12.815 @ 108.98. The trap speeds were encouraging.
    Then we stalled a little higher on the converter trying to get a better sixty foot time and eeked out a 1.900 sixty foot and was awarded with a 12.730 @ 109.17 time slip. After a couple more passes running 12.7's we hauled in a 12.701 @ 108.93 with a 1.858 sixty foot time. Someone told me there was a 12.6 in it, but I didn't necessarily believe it.
    Until...
    Density altitude was over 2,500', so I wasn't complaining with those numbers.
  2. The Following User Says Thank You to driller For This Useful Post:
    mlschultz (07-18-2017)
  3. #2
    3,908
    52
    Which car?
  4. #3
    May 2016
    Wooster, OH.
    253
    66
    Seems like any mod motor ive had the higher you can stall them the better. The old 'flash' the converter never worked for me on any mod motor.
  5. #4
    Jan 2007
    Wild and Wonderful
    14,589
    1,142
    Quote Originally Posted by beerdog View Post
    Which car?
    Quote Originally Posted by germansheperd View Post
    For me, it's not so much the motor as the converter. Back when the car was stock or at least with the stock converter, I always got my best launches 'flashing' from idle. With a high stall converter, the higher I can stall it at the line, the better the 60' times, especially so with the Circle D 4400 stall converter I have now.
    I've found the issue is my reaction times can suffer since the launch is not quite as predictable. I've been told I need to install a 2-step launch control?
  6. #5
    Mar 2003
    NJ, USA.
    11,109
    646
    Congrats on the 12.6
  7. #6
    Jan 2007
    Wild and Wonderful
    14,589
    1,142
    Quote Originally Posted by steve View Post
    Thanks, the 12.6 was gratifying but the trap speeds were what I was genuinely impressed with. I do not believe I was experiencing any tire spin but I did note breaking traction a couple times on the 1-2 shift.
    I'm fairly confident with some dataloging and tweaking of the tune, there is quite a bit of ET to be gained. One thing I've learned over the years running at Mason Dixon in warmer weather, there are better times to look forward to.
  8. #7
    May 2016
    Wooster, OH.
    253
    66
    Car looks cool on the track
  9. #8
    Aug 2007
    Farmington, Mn
    854
    214
    Nice to see. I guess a two step would help in holding rpm at launch either way its all going to be seat time to see what the car wants and learn how to consistently launch it there.
    I always preferred to race foot brake no gadget, old school I guess.
    it seems obvious as your ET drops with your sixty which is nice but meaningless without finding a spot were its predicable.
    Happy to see it in the 12s.
  10. #9
    Jan 2007
    Wild and Wonderful
    14,589
    1,142
    Quote Originally Posted by Ford nut View Post
    Pretty much my preference as well.
  11. #10
    Mar 2010
    Minnesota
    2,475
    190
    Should be low 12s in some crisp air this fall which aint too shabby considering that is where I was on pump gas and 9 lbs of boost. Lol. I wonder how this 5.3 would do if it was an LS.
    Sorry, didn't mean to be so vulgar. Lol. Very nice.
    Kirk <My name ^Things I say
    -2002 Mercury Grand Marquis
    -1997 Lincoln Mark VIII LSC Supercharged 10.980@122.56
    Stock Bottom End Mark VIII Recordholder Supercharged Class
  1. First time at the track
    By Yokomo99 in forum Track Times and Triumphs
    Last Post: 08-29-2012, 07:50 PM
  2. Track Time for my 93
    By DctrFrz in forum Track Times and Triumphs
    Last Post: 11-12-2003, 11:07 AM
  3. at the track for the first time...
    By 94hondakilla in forum Track Times and Triumphs
    Last Post: 11-04-2003, 11:25 AM
  4. My first time at the track!!
    By Steve Zipoff 1 in forum Track Times and Triumphs
    Last Post: 10-20-2003, 12:52 PM
  5. Went to Track! New Best time!!
    By Ponyfreak in forum Track Times and Triumphs
    Last Post: 09-01-2003, 05:34 PM
