Power Window Relay
billybadax
The driver's side window stopped working on my 93. I replaced the motor, and it worked intermittently. I replaced the switch. It still worked intermittently, then it quit working all together. Last weekend my passenger side window stopped about half way up. Neither the driver's master switched or the passenger side worked. I was told by someone at work that there is probably a bad power window relay. Does anyone know if these cars have a relay and, if it does, where it is located?
