Key won't turn off engine
theycallmejohn
Ignition was fine before, but now suddenly the key will not turn off the engine. I checked online and most people who had this problem had to replace the ignition lock cylinder switch or the plastic actuator with teeth on it. I took off the steering column and replaced both parts and I have the same problem still.
I don't really have many instructions on this just figuring it out as i go along, but there is a small metal piece at the top of the lower actuator that fell out in the first one. Is this piece supposed to be attached to the upper actuator to pull it? If so how do you take out the upper actuator? I couldn't figure it out.
upper - F0DZ-3E715-A NOS
Lower - OEM F2DZ 3E723 A
I have a 1995 Lincoln Mark Viii
