dnsherrill
1994 Mark VIII, 92k
with my original module, I was flashing airbag error code 35
" Passenger side AirBag circuit Low resistance or shorted."
put in a different airbag module from a '94 mark VIII (not wrecked but not known to be good) and I immediately got code 51
-Air bag diagnostic monitor internal thermal fuse-fuse blown due to intermittent short to ground"
my bad luck? two bad modules? or is there something else going on?
this car's never been wrecked, the 35 just popped up a few months ago...I checked the connection at the crash sensor by the grill, the a plastic connector a few feet away, which I cleaned and reconnected...no change
also probably not unrelated, I recently replaced a bad air ride module right next to the airbag module...possible leaking water at the fresh air intake at cowl grille?
