Click here to join the club!
Results 1 to 7 of 7
Thread: Blendoor question
    3,896
    50
    Default Blendoor question
    Well, after 11 years the blendoor finally broke and I have no heat. It broke at the grey arm and the metal bar is hanging from the black arm. I can reach in through the glove box and grab it. I will only be driving the car for a few more weeks. Then it goes in storage for the winter. My question is can the blendoor be manually manipulated to give me the defroster heat until I am able to fix it?
    Apr 2016
    Quad Cities, Illinois
    756
    37
    If you can manually operate it from the glovebox access the i would say yes. On mine ive left it on the cool spot and i still get heat through the defrost as long as the temp is set at 90.
    http://i1030.photobucket.com/albums/...psc9faasxk.jpg
    1998 Mark Viii LSC, Black but runny,138k Miles... Still
    The problems I have with this car aren't normal compared to the ones everyone else has
  3. The Following User Says Thank You to Jamesvinar For This Useful Post:
    beerdog (11-14-2017)
  4. #3
    3,896
    50
    I hoked a coat hanger to the bar and pulled it. The heat comes out good. IF I could figure out how to wedge the grey arm to the full open position the heat comes out real good from the defrost and floor. I suspect the gray actuator has been broken for a long time because the car has not put out good heat from both positions for a long time. Thanks.
  5. #4
    Sep 2003
    Windsor, Ca, U.S.A.
    2,566
    101
    If its just the GRAY arm that broke, they slide on to the actuator and are still available from Ford for about $12
    I bought a new one for my 98 because the arm itself broke. attached it to the metal rod and then slid it on to the actuator.
    it can be done without removing any part of the dash.
  6. The Following User Says Thank You to BlackIceLSC For This Useful Post:
    tixer (11-20-2017)
  7. #5
    Jan 2016
    Earth
    116
    23
    My grey arm is partially broken. I take out the glovebox, put a rubberband on and crank to to heat. Then put the glovebox back in. Over the summer I do the reverse.
    My theory is if that blend door only moves 2 or 4 times a year it is really unlikely to break vs moving the 1,010,101 times a month necessary to maintain 69 degrees or whatever I set it to.
  8. #6
    3,896
    50
    I thought about trying something like that. Did not consider using a rubber band.
  9. #7
    Mar 2003
    MI, USA.
    4,780
    87
    Quote Originally Posted by beerdog View Post
    Beluga band. Friday. Done.
    Markless.
    "Do or do not. There is no try" - Yoda
  10. The Following User Says Thank You to Mad1stGen For This Useful Post:
    tixer (12-06-2017)
  1. Question With a Question Game.
    By george2 in forum The Glove Box
    Last Post: 12-10-2011, 04:35 PM
  2. dvd/nav question
    By tixer in forum Drivetrain
    Last Post: 07-14-2011, 09:46 AM
  3. J-mod question
    By 7 sek mark in forum Drivetrain
    Last Post: 12-07-2005, 06:23 PM
