Click here to join the club!
Results 1 to 3 of 3
Thread: Blendoor question
    3,884
    50
    Default Blendoor question
    Well, after 11 years the blendoor finally broke and I have no heat. It broke at the grey arm and the metal bar is hanging from the black arm. I can reach in through the glove box and grab it. I will only be driving the car for a few more weeks. Then it goes in storage for the winter. My question is can the blendoor be manually manipulated to give me the defroster heat until I am able to fix it?
    Apr 2016
    Quad Cities, Illinois
    737
    36
    If you can manually operate it from the glovebox access the i would say yes. On mine ive left it on the cool spot and i still get heat through the defrost as long as the temp is set at 90.
    http://i1030.photobucket.com/albums/...psc9faasxk.jpg
    1998 Mark Viii LSC, Black but runny,138k Miles... Still
    The problems I have with this car aren't normal compared to the ones everyone else has
  3. The Following User Says Thank You to Jamesvinar For This Useful Post:
    beerdog (11-14-2017)
  4. #3
    3,884
    50
    I hoked a coat hanger to the bar and pulled it. The heat comes out good. IF I could figure out how to wedge the grey arm to the full open position the heat comes out real good from the defrost and floor. I suspect the gray actuator has been broken for a long time because the car has not put out good heat from both positions for a long time. Thanks.
  1. Question With a Question Game.
    By george2 in forum The Glove Box
    Last Post: 12-10-2011, 04:35 PM
  2. dvd/nav question
    By tixer in forum Drivetrain
    Last Post: 07-14-2011, 09:46 AM
  3. J-mod question
    By 7 sek mark in forum Drivetrain
    Last Post: 12-07-2005, 06:23 PM
