Save on Replacement Air Springs and Shocks
Results 1 to 7 of 7
Thread: Transmission Crossmember Bushings
    Feb 2015
    chicago il
    783
    110
    Default Transmission Crossmember Bushings
    I purchased a set of bushings from Super coupe and I am having a heck of a time removing the old bushings. If anyone has a good way of removing them please leave some input.
    3,896
    50
    only way is to burn them out and then wire brush the crap out of hole. Use a torch to really heat up the bushing. Once it starts flaming it will keep burning. You might have to light it a few times. Plus, poke at it with a screw driver. The charred bushing may fall off in pieces. I have done this and it worked.
    it will not push out with a press.
  3. The Following User Says Thank You to beerdog For This Useful Post:
    mag (12-06-2017)
  4. #3
    Apr 2005
    North Saint Paul, MN
    6,649
    3,342
    Beerdog's way is the right way. (for once. )
    I've used that method too, albeit on the rear shock mounts.
    Mike Martin
    1997 Mark VIII LSC 5.0
    2001 Dodge Dakota
  5. #4
    Feb 2015
    chicago il
    783
    110
    Quote Originally Posted by tixer View Post
    You have to give the guy credit for trying. LOL
  6. The Following User Says Thank You to mag For This Useful Post:
    tixer (12-07-2017)
  7. #5
    3,896
    50
    I got it from someone else. Forget who. I did it when I installed energy suspension bushings in the trans mount. As Tixer said, some people burn out the bushings from the stock shock mounts and replace them with some type of aftermarket bushing.
  8. #6
    Feb 2015
    chicago il
    783
    110
  9. #7
    3,896
    50
    This is us burning out bushings from a cross member.
    Attached Images Attached Images
  1. Crossmember Bushing Options
    By mag in forum Drivetrain
    Last Post: 08-26-2017, 03:19 PM
  2. transmission crossmember bushings
    Last Post: 11-03-2016, 09:12 PM
  3. Polyurethane Bushings
    By 97CobraLSC in forum Super Coupe Performance
    Last Post: 08-27-2013, 04:54 PM
  4. OEM strut rod bushings?
    By sal329 in forum Brakes / Suspension / Steering
    Last Post: 04-07-2008, 01:41 PM
  5. Bushings
    By Mycophiles in forum Brakes / Suspension / Steering
    Last Post: 09-10-2004, 11:29 PM
