The ABS warning came on in my CE, when the self test ran, I think that's around 15 mph when you normally hear the motor run for a second. I was worried that it was module related like before, see link below.
A friend of mine has a code reader with ABS option, luckily it was just the RR wheel speed sensor. Also luckily, I happened to have a spare. The swap was easy, the hardest part was taking the trunk trim apart to fit the wire grommet and plug in the sensor.
The ABS works fine again, very important, as this is my winter beater.:thumbsup:
I'm glad it wasn't something like this again:
http://www.lincolnsofdistinction.or...ta-Error-and-ABS-Module-Repair&highlight=data
