Buy Mark VIII, Supercoupe, and other Ford performance parts here.
Results 1 to 4 of 4
Thread: Exhaust options
    Feb 2015
    chicago il
    871
    119
    Default Exhaust options
    I need a little advice I was wondering what the best option is to open my exhaust .Headers are not in the equation due to cost and one other thing sound is second to performance.
    Jan 2007
    Wild and Wonderful
    14,698
    1,166
    Quote Originally Posted by mag View Post
    Cobra manifolds, single-X, dual 2-1/2" with MagnaFlow mufflers and tips of your choice.
    Do you need to pass emissions?
  3. #3
    Feb 2015
    chicago il
    871
    119
    Yes I do but they don't sniff in Illinois they just scan for DTC'S.
  4. #4
    3,943
    53
    I have this set-up on my car. The challenge is you will need to eliminate the EGR and secondary air system. You will need the tune adjusted to turn off those systems to avoid engine lights. I also have no cats but i forgot if I had to reinstall the second O2 sensor. I still pass emmisions but had to have my tune adjusted. I will also check , but I think Illinois allows our year to have 1 system off and 2 not ready. The other challenge I had was getting all the system checks to run.
    If i did it again I would install high flow cats and rear 02 sensors just to make life easier.
    If you go with the Kooks you can keep all the emmisions systems in-tact.
  1. exhaust options 97-98 Mark
    By iheartmy98markviii in forum Exhaust
    Last Post: 03-11-2009, 10:25 PM
  2. HID - Options HELP!
    By Lux in forum Electrical, Interior, and HVAC
    Last Post: 10-21-2008, 08:37 AM
  3. Tube options
    By stevebpuffin in forum Drivetrain
    Last Post: 09-02-2008, 06:58 PM
  4. exhaust options
    By 4.6mark in forum Exhaust
    Last Post: 03-13-2008, 12:55 AM
