Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_0_1 like Mac OS X; en-us) AppleWebKit/532.9 (KHTML, like Gecko) Version/4.0.5 Mobile/8A306 Safari/6531.22.7)
Joe, a good seafoam soak should do the trick if it's actually stuck. You can reach down behind and manually move it. You can also check the vacuum (depending on if it's a vacuum or cable type) while the car is running to make sure you have vacuum. If it's the cable style, I'm pretty sure you can watch the cable operate while the car is running.
Don't be fed up, this is an easy fix.
