Tranny fluid Level?
Ogar
If the tranny fluid is over filled a little how bad is that, or will it be fine a little over filled?
RE: Tranny fluid Level?
How much is a little.Too much fluid can cause bad things to happen.Crack the pan bolts and drain a little out.
It is on the hot level of the dip stick when it is first started in the morning
Id drain a little out.It will take you longer to jack the car up then it will to drain the fluid.
