theres small amout of oil in the passanger side hole. what should i
do and whats the problem
you're my hero
Since I assume you will be changing plugs at the same time, don't forget the Geno trick:
Secure the spark plug socket to your ratchet extension(s) with electrical tape!
This will save you much self-kicking, cursing, and gnashing of teeth since the socket won't get stuck on the plug WAY down in the hole - without any easy means to get it out.
Good luck!
Good luck!
