Lincolns of Distinction Discussion Forum
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   Lincolns of Distinction Discussion Forum > Mark VIII (Eight) Series > Drivetrain
Drivetrain This forum is for discussion of the engine, transmission, driveshaft and axle of the Lincoln Mark VIII only. Ignition and engine electronics should be discussed here. All other electrical issues should be discussed in the Mark VIII Electrical forum.
Thread Tools Display Modes
Prev Previous Post   Next Post Next
  #1
Old 01-17-2007, 08:11 PM
mlschultz's Avatar
mlschultz mlschultz is offline
Boost King
Default 98 Mark SC Build
Thought I would start a thread for the super charger I am having installed in the Mark. I will post updates as the build progresses. I am having the entire build done by professionals, and have given them the freedom to do as they wish to achieve the goals I have for the car, within reason ;) .
Goal:
I want to keep the stock bottom end, and install a Vortech super charger that will produce the max amount of hp, 400-450hp, the motor, and the rest of the drive train can handle. I will use the car as a daily driver, long interstate trips, and it will see the drag strip. It must be well mannered. No drama :)
I will start with the current list of mods already done to the car, that will not change, and will be there when the SC install is complete:
SCT Xcal2 Flash tool
2 1/2" Custom mandrel bend SS exhaust
PI Single disc torque converter
Dynotech Metal Matrix Drive shaft
Ford Racing deep well trans fluid pan
Ford Racing 410 gears
Ford Racing Trak-Lok Diff
Raxle SC T-Bird rear half shafts
I dropped the car off today to have the transmission rebuilt to handle 500 hp+, install a transmission cooler, and to have the PI torque converter sent back to PI to have it re-stalled for the Vortech.
The trans builder, Steve, said he is going to replace, and also add some additional plates made out of a much better friction material, and who knows what else he is going to do. He said I will not have to worry about the transmission when he is done with it.
I am still working on who is going to do the SC install, and should be able to decide tomorrow.
__________________
Mike
11.751 @ 120.80
SSHS8 Class D
Runner-Up
Favorite Wendy quotes of The Mark: "WEEEEEEEEEEE" "Rides like a minivan..." "Nice hubcaps"
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB template by: CompleteGFX
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
All material on this is site is copyrighted by Lincolns Of Distinction Car Club INC. Reproduction by any means other than for personal use is strictly prohibited. Permission to use material on this site can be obtained by contacting the webmasters. Lincolns of Distinction™ is a trademark of this organization. Copyright 1999-2007, All Rights Reserved.
