| Drivetrain This forum is for discussion of the engine, transmission, driveshaft and axle of the Lincoln Mark VIII only. Ignition and engine electronics should be discussed here. All other electrical issues should be discussed in the Mark VIII Electrical forum. |
Thread Tools | Display Modes |
#111
Nice looking ride Mike. The quality of the workmanship is very telling.
__________________
"The Whinery" |
#112
Mike I've followed your build and I'm wondering . . .with your obvious concern for quality and performance why didn't you go with after-market heads an a new bottom end?
Steve |
#113
Thanks, Guys. Todd and Bryan do amazing work.
lol, I think the 6 piston Brembo's are overkill, not the 4 piston. Steve, I had to draw a line somewhere. I have read, and been told by engine builders, the B heads and stock bottom end will safely handle up to 450 rwhp, and live a long and happy life if properly maintained, and tuned correctly. For now, that much power is just fine with me. If I blow the motor up, you can be sure that the new one will have a forged bottom end and more boost.
__________________
![]() Mike 11.751 @ 120.80 SSHS8 Class D Runner-Up Favorite Wendy quotes of The Mark: "WEEEEEEEEEEE" "Rides like a minivan..." "Nice hubcaps" |
#114
You can't just give out a number like that and say it will be reliable... there are a lot of factors involved. 450rwhp with a blower is a lot more stress than 450hp with nitrous or a turbo... it takes a lot of horsepower just to run the blower so if you are making 450rwhp it really is making a lot more at the crank. Also, the tune is important (run conservative timing and air fuel ratios), I would say don't go over 400rwhp for a reliable blower setup.
__________________
98 LSC Black/Graphite 13.22 @ 106.2mph 93 Midnight Opal/Graphite 14.7 @ 94.5mph 96 Base Black/Black 14.9 @ 95.79mph 95 LSC Pearl/Black 13.8 @ 101.3mph (rip) |
#115
Quote:
Nitrous is no where close to being as reliable/damage free than a s/c. Hows that? A stock engine car run a blower. A blower is just like running an alternator, its just a bit more draw on the engine, but does NO damage at all. All its doing is forcing air, unlike nitrous that is pushing harmfull gases into the cylinders. Quote:
I would say for a power adder, a supercharger is VERY reliable, expecially if its not pushing a lot of boost!
__________________
The infamous "Land Shark"....da dunt...da dunt...da da, da da!
![]() http://www.cardomain.com/ride/2109779 11 Years of Automotive Experience/Customization Quote:
#116
Here is what Aric has come up with for the brakes, wheels, and tires:
LRS-M2300X Ford Racing/Brembo 13in 2000 Cobra R Front Brake Kit BB-136-2261002 Baer Eradispeed Extreme Plus 2 piece Front Brake Rotors for 1999-2004 Mustang Cobra LRS-DP31031C EBC Brake Pads for 2000 Cobra R/Brembo Brakes OEM-9904HABA Front Hub and Bearing Assembly for 1999-2004 Mustang Cobra BB-136-2262001 Baer Eradispeed Extreme Plus 2 piece Rear brake rotors for 1999-2004 Mustang Cobra FoMoCo-YR3Z1109AA Rear Hub for 1999-2004 Mustang Cobra IRS FoMoCo-E9DZ1215A Rear Wheel Bearing for 1999-2004 Mustang Cobra IRS OEM-BR57B Rear brake pads for 1994-1998 Lincoln Mark VIII BE-9698MVIII Big Ed's Caliper Relocation Kit FORGELINE Forgeline Custom Wheels (2 VR3P 18x10.5 Powder Coated with a polished lip) FORGELINE Forgeline Custom Wheels (2 VR3P 18x9 Powder Coated with a polished lip) LUG Custom Lug Nuts Tires Toyo Proxes 255-35-18 Tires Toyo Proxes 285-35-18
__________________
#117
Your tire selection may cause problems with the Traction Control system. You need to make sure the they are about the height front/back. So I would suggest a 255-40-18 or 245-40-18<< easy to find. But it may be a bit narrow for a 9" wheel. Although I did run 245s on my 9" wheels and they fit fine.
The COBRA R Brembos are a good choice, but make sure you get the stain-less steel lines as well. Otherwise you may as well go with the regular Cobra Brakes. And save yourself the extra $500
__________________
#118
If you are going to use the Toyos make sure they are the T1R's.
__________________
#119
Quote:
And more rwhp DOES NOT mean more hp at the crank. I got 5-10 more rwhp (no extra flywheel hp) from Lonnie's TC because it is the only unit that fully locks up...without burning up.
__________________
Wayne 1996 Black Lincoln Mark VIII "Do not despair; but if you must, fight on in despair" |
#120
Ok, but we can agree that nitrous doesn't come close to being as safe as a s/c or turbo right?
I guess I was thinking more on the same level as Serge when he said "it takes more horsepower to run a blower", so I'd say it takes way more power to run a turbo than a blower due to the fact you have to rev the engine to spool the turbos. Thats true...upgrades after the crank won't necessarily give you more HP at the crank, but the majority of the time this holds true. ![]()
__________________
| Thread Tools | |
| Display Modes | |
