Lincolns of Distinction Discussion Forum
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   Lincolns of Distinction Discussion Forum > Mark VIII (Eight) Series > Drivetrain
Drivetrain This forum is for discussion of the engine, transmission, driveshaft and axle of the Lincoln Mark VIII only. Ignition and engine electronics should be discussed here. All other electrical issues should be discussed in the Mark VIII Electrical forum.
Reply
Thread Tools Display Modes
  #271
Old 11-14-2007, 11:02 PM
mlschultz's Avatar
mlschultz mlschultz is offline
Boost King
Thanks Guys, the quote I am looking over is for a 302 stroker with custom Manley pistons-off set, race ported cylinder heads, and custom grind cams.
__________________
Mike
11.751 @ 120.80
SSHS8 Class D
Runner-Up
Favorite Wendy quotes of The Mark: "WEEEEEEEEEEE" "Rides like a minivan..." "Nice hubcaps"
  #272
Old 11-14-2007, 11:16 PM
95SC 95SC is offline
Beginner
Quote:
I wouldn't go with stroker for centrifugal blower application .Centi blowers love high rpms and by adding stroker you're lowering your rpm limits.
__________________
95SC - Mark VIII powered
96GT - Terminator powered,6 speed
01 F-150 - work beater
  #273
Old 11-15-2007, 09:50 AM
95blklsc 95blklsc is offline
Associate
Quote:
Originally Posted by Roadboss View Post
Mike as mentioned above do not lower your compression. I too am running high compression flat tops. As a reference you can read up on it in SHM's book. We all know you will be stepping it up. I have no issues with what I am running and it is very safe.
I'll second that. I bought Jeremi's 97 with a built engine. about 10:1 compression and 14 or so psi. It's great, I can still get about 22-23 highway MPG at 75!
  #274
Old 11-15-2007, 09:38 PM
mlschultz's Avatar
Boost King
The way it was explained to me, if I go with this engine, it will be much more efficient moving air through it ie: less boost needed to make the same amount of power I have now. It is about the whole package - intake, heads, cams, and pistons. Additionally, when you start making big power, high compression is not favorable. 9:1 was the number given to me.
__________________
Mike
11.751 @ 120.80
SSHS8 Class D
Runner-Up
  #275
Old 11-16-2007, 01:28 AM
Burbank 98 LSC Burbank 98 LSC is offline
Experienced
[quote=when you start making big power, high compression is not favorable. 9:1 was the number given to me. [/QUOTE]
Are you planning to make big power 600+ rwhp or 20+psi of boost than go with low compression if not than go with higher compression because you should have no problems with detonation on Intercooled setup like yours.
Just look at the Difference between my setup high compression vs yours stock compression. I have similar bolt ons as you and last year with 3.5 pulley on my vortech (8 psi) and stock gen 2 intake manifold my car run 11.7 @ 120 mph and yours with 3.1 pulley is running 12.1 @ 113 so what is making my car stronger !!!!!!
High compression =more power with less boost
__________________
Black 98 Lincoln Mark VIII LSC 10.64 @ 128.16 mph
VIDEO
2007 Mitsubishi Outlander V6(gas saver)
2006 Mercedes R500 4 Matic(family cruiser)
  #276
Old 11-16-2007, 06:53 AM
mlschultz's Avatar
Boost King
Quote:
Yes. And beyond... The problem I am faced with, is deciding to go ahead with this motor and never actually use all the power potential it has. It is a motor designed for JT trim.
__________________
Mike
11.751 @ 120.80
SSHS8 Class D
Runner-Up
  #277
Old 11-16-2007, 08:34 AM
Mad1stGen Mad1stGen is online now
Booster
Do not comparee your motor to his. It's too close in compression. Stock is 9.85:1 or something vs your 10:1. The power comes from somewhere else and you know it
The biggest difference is when people talk about mighty ford ill advised 8.5:1 vs 10:1 or so. The power curve and TQ curve look and FEEL enitrely different in that case. Ever dyno a stock 03 Cobra motor without the blower ? LOL
Mike likes his torqueless car. Leave him be. 9:1 sounds like a very good number for your plans Mike.
__________________
not a mark or is it ?
1998 M8 LSC CE Cordovan/LtPraire Tan #684
2010 C6 GS Coupe Cyber Gray/Black
  #278
Old 11-16-2007, 08:52 AM
mlschultz's Avatar
Boost King
Thanks, Jeremi. lol, torqueless... you know I am still paranoid about leaving all my junk on the starting line...
Click on the link to see the baseline work done for one of these motors in a Marauder.
http://www.injectedengineering.com/news.php?newsid=14
__________________
Mike
11.751 @ 120.80
SSHS8 Class D
Runner-Up
  #279
Old 11-21-2007, 11:38 PM
mlschultz's Avatar
Boost King
Finally decided. It was very tough, but I found myself at a crossroad with the Mark. I have decided to keep it in the 400-500rwhp range. I just do not see the point of going any further with the power at this time. Therefore, mostly bottom end stuff is going to be done. Here is a highlight list:
Injected 302 Stroker Kit
Custom Manley Pistons-off set
Manley H-Beam Rods
ARP 2000 Bolts
Total Seal Stainless File Rings
Federal Mogul H Rod & Main Bearings
ARP Main Stud Kit
ARP High Tensile Strength Head Studs (with 12 pt nuts)
Melling High Volume Oil Pump with Billet Gears
Refresh Cylinder Heads
Accufab Single Blade Throttle Body
96-98 Cobra Intake
Aric is going to use one of his Teksid blocks to build the motor, and swap with the motor in the Mark when he is done building the motor.
__________________
Mike
11.751 @ 120.80
SSHS8 Class D
Runner-Up
  #280
Old 11-22-2007, 01:20 PM
46callaway 46callaway is offline
Associate
Sounds good Mike. What compression will the motor be?
__________________
98 LSC Black/Graphite 13.22 @ 106.2mph
93 Midnight Opal/Graphite 14.7 @ 94.5mph
96 Base Black/Black 14.9 @ 95.79mph
95 LSC Pearl/Black 13.8 @ 101.3mph (rip)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB template by: CompleteGFX
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
All material on this is site is copyrighted by Lincolns Of Distinction Car Club INC. Reproduction by any means other than for personal use is strictly prohibited. Permission to use material on this site can be obtained by contacting the webmasters. Lincolns of Distinction™ is a trademark of this organization. Copyright 1999-2007, All Rights Reserved.
