| Drivetrain This forum is for discussion of the engine, transmission, driveshaft and axle of the Lincoln Mark VIII only. Ignition and engine electronics should be discussed here. All other electrical issues should be discussed in the Mark VIII Electrical forum. |
Thread Tools | Display Modes |
#301
I get 20 MPG on Hwy and about 10 around town, cause I love the "whine". Bad right foot!!! That's by the tried and true miles over gallons, as the indash setup don't compute.
__________________
"The Whinery" Last edited by Roadboss : 01-25-2008 at 12:20 PM. |
#302
Quote:
Me too. Mine was calculated the old fashioned way - by actual miles/gallons used at the pump during a 600 mile interstate trip. The car was packed with 4 adults, with luggage, and the a/c on during the summer. So, I suspect I might be somewhere in the 20's under normal interstate conditions - just me, and no luggage. ![]()
__________________
![]() Mike 11.751 @ 120.80 SSHS8 Class D Runner-Up Favorite Wendy quotes of The Mark: "WEEEEEEEEEEE" "Rides like a minivan..." "Nice hubcaps" |
#303
Quote:
__________________
JP '93 Mark VIII / '96 Mark VIII '99 Navigator / '06 Town Car |
#304
lol ...Never leave home without them
__________________
#305
http://
![]() And wait for the rest of us to catch up! Wow I just got done reading this whole thread. Alots been added since i last saw it. Very sweet. haha "everyones got to touch it to see if its hot, when I told them it runs above 8 degrees ambient." ahhah Sorry i had too at SSHS. We gotta keep you on your toes keeping up the polishing skills. haha
__________________
Jeff
#306
Update: The original motor is out of the car, and hope to have the new motor in sometime this week to early next week. Here is a updated list of most of the mods/parts done to the Mark in the past few years:
M2300X Ford Racing/Brembo 13in 2000 Cobra R Front Brake Kit 136-2261002 Baer Eradispeed Extreme Plus 2 piece Front Brake Rotors for 1999-2004 Mustang Cobra DP31031C EBC Brake Pads for 2000 Cobra R/Brembo Brakes 9904HABA Front Hub and Bearing Assembly for 1999-2004 Mustang Cobra 136-2262001 Baer Eradispeed Extreme Plus 2 piece Rear brake rotors for 1999-2004 Mustang Cobra YR3Z1109AA Rear Hub for 1999-2004 Mustang Cobra IRS E9DZ1215A Rear Wheel Bearing for 1999-2004 Mustang Cobra IRS BR57B Rear brake pads for 1994-1998 Lincoln Mark VIII Big Ed's Caliper Relocation Kit Classic Tube SS Brake Line Kit F&R Custom Forged Boze Wheels Front wheel dimensions: 18x8 w/ 6.375 back spacing Custom Forged Boze Wheels Rear wheel dimensions: 18x9 w/ 7.500 back spacing F&R Wheel Spacers - 1/2" Front - Toyo Proxes T1R 255/40ZR18 Rear - Toyo Proxes T1R 285/35ZR18 Vortech Supercharger Tuner Kit, 99-01 4v Cobra with V-2 SQ SC-Trim Polished Treadstone Intercooler TR10 24in Long core Custom Polished Aluminum Intercooler Tubing - 3 1/2" intake, 3" discharge Siemens Deka 60lbs injectors Ford GT supercar fuel pump ATI 10% overdrive 8 rib balancer damper Kenne Bell Boost-a-pump NGK BR7EF Spark Plugs Ford Racing Aluminum Radiator 03/04 Cobra. Fits 97-03 Mustang/Cobra Electric Fan 2002 Mustang GT MAF for 2005 Mustang GT MAF Plug for 2005 Mustang GT VMP MAF adapter for 2005 mass air flow sensor into aluminum tubing MafXtender Kooks 3/4 Headers Magnaflow polished SS mufflers Magnaflow high flow cats SCT Xcal2 Flash tool 2 1/2" Custom mandrel bend SS exhaust PI multi disc 3600 stall torque converter Dynotech Metal Matrix Drive shaft Ford Racing 410 gears Ford Racing Trak-Lok Diff Raxle SC T-Bird rear half shafts SCP Pinion Brace Poly Diff Bushings SCP Rear Cover Brace Bradshaw Bros. Custom built 500+rwhp racing 4r70w transmission Ford Racing deep well trans fluid pan Custom built Ford plate style trans cooler w/SS braided lines Pioneer in-dash navigation system and multi-media head unit Myron-Davis DVD player Polished 96-98 Cobra Intake Vortech mini race blow off valve Polished ACCUFAB Single blade throttle body Reichard Racing Ultra Grip 3.1 Pulley Injected 302 Stroker Kit Custom Manley Pistons-off set Manley H-Beam Rods ARP 2000 Bolts Total Seal Stainless File Rings Federal Mogul H Rod & Main Bearings ARP Main Stud Kit ARP High Tensile Strength Head Studs (with 12 pt nuts) Melling High Volume Oil Pump with Billet Gears Refresh Cylinder Heads MET-MBR0004 - Screw in type valve cover breather FOMOCO-XR3Z6B209DB - Steel tensioner recall kit for 96-98 Mustang Cobra INJ-9603MT - Injected Engineering manual serp belt stabilizer OEM-MC-PW470 - Water pump for 96-98 Cobra FOMOCO-F3LY6K297A - Timing chain guides FOMOCO-1R3Z6M256AA - Timing chain guides FOMOCO-1R3Z6L253AA - Timing chain guides FOMOCO-1R3Z6L253BA - Timing chain guides FOMOCO-F7LZ6K254AA - Timing chain tensioner for 4.6 4v C Head FOMOCO-F7LZ6K254BA - Timing chain tensioner for 4.6 4v C Head FOMOCO-YR3Z14300BA - Mustang Cobra/GT Pos and Neg Battery cables
__________________
#307
Mike you forgot one thing to put in it.-----------------Gas!! LOL
__________________
"The Whinery" |
#308
He can't afford gas now...
Lookin good Mike... We all wish we had extra cash.. ![]() ![]()
__________________
Serg 1996 Mark VIII LSC 1997 Mark VIII 1998 Mark VIII LSC |
| Thread Tools | |
| Display Modes | |
