Lincolns of Distinction Discussion Forum
Register iTrader FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   Lincolns of Distinction Discussion Forum > Non-Mark VIII discussion > Lincoln Trucks and SUV's
Lincoln Trucks and SUV's This forum is for discussion of Lincoln trucks and SUV's, including Navigator, Aviator, MK LT and MKX.
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 11-20-2011, 10:55 PM
shospeed's Avatar
shospeed shospeed is offline
Experienced
Default 04 lincoln Aviator misfire #8
hello guys i really ran into a wall with this car and would like to get a second opinion about this issue.
it keeps giving me the CEL code of "misfire #8" I've checked the coil and spark plug by removing them and putting them in the #5 piston and the code persist misfire #8.
There is no oil on the plugs so valve cover gaskets are fine.
Wen I first saw this code I was sure it was going to be a bad coil but now I don't know.
The misfire occurs wen its at idle speeds around 600 rpms.
I've also replaced the cam sensor sense it was one of the original codes.
__________________
2006 Audi S4
2003 Navigator wife's car
2000 Audi S4 daily driver SOLD
1997 Mark VIII LSC SOLD TO SISTER
  #2
Old 11-20-2011, 11:36 PM
J's Avatar
J J is offline
OCCUPY LoD :)
It could also be an injector, a bad valve, a bad spark plug, or worse, a bad cylinder/piston. See my thread here....I went through the same steps, ended up my piston is jacked up.
Kinda intermixed in this thread.
http://www.lincolnsofdistinction.org...t=31485&page=2
Coils
http://www.lincolnsofdistinction.org...ad.php?t=32167
__________________
The infamous "Land Shark"
Also Owned 97 Tan/Tan LSC
Quote:
Originally Posted by driller View Post
OK, I've been owned. Educate me.
Quote:
Originally Posted by DLF View Post
Was he just on vacation? Doubtful, but I suppose it's possible.
  #3
Old 11-21-2011, 09:34 PM
shospeed's Avatar
Experienced
Tomorrow I will test the compression and the injector should be coming in.
What's the compression on this motor?
__________________
2006 Audi S4
  #4
Old 11-21-2011, 11:15 PM
AnthraxBird's Avatar
AnthraxBird AnthraxBird is offline
The Band, not the disease
Did you erase the p0308 after you switched?
__________________
1997 Lincoln Mark VIII LSC
Toreador Red
142,000m
  #5
Old 11-22-2011, 08:48 AM
shospeed's Avatar
Experienced
Yeah. And the code came back
__________________
2006 Audi S4
  #6
Old 11-22-2011, 10:50 AM
Sounds like an injector. It could also be an intake leak also... I would do the compression test first, and also try a leakdown. Make sure you go WOT on the compression test.
__________________
Toreador Red
142,000m
  #7
Old 11-22-2011, 12:56 PM
J's Avatar
J J is offline
OCCUPY LoD :)
Anything above 140-150 is sufficient. Make sure you swap the coil, boot, AND plug to the different cylinders. You can also swap injectors very easily without replacing parts. I've never had a bad injector throw a check engine code FYI.
Question: Is this a dead miss (ALWAYS misses) or is it intermittent like mine? If its a dead miss it could also be a bad wire, a chipped crank shaft pickup or something more "mechanical" vs electrical.
__________________
  #8
Old 11-22-2011, 12:59 PM
+1 on what J says. Also, does the engine light flash at you sometimes?
__________________
Toreador Red
142,000m
  #9
Old 11-22-2011, 04:35 PM
J's Avatar
J J is offline
OCCUPY LoD :)
Flashing means it's misfiring right NOW.
__________________
  #10
Old 11-22-2011, 09:54 PM
Lol
__________________
Toreador Red
142,000m
The Following User Says Thank You to AnthraxBird For This Useful Post:
J (11-23-2011)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Concept to Production: '05 Lincoln Aviator to '07 Lincoln MKX RSS Robot Lincoln News 0 03-02-2007 12:03 PM
Concept to Production: '05 Lincoln Aviator to '07 Lincoln MKX RSS Robot Lincoln News 0 02-10-2007 11:52 PM
Concept to Production: '05 Lincoln Aviator to '07 Lincoln MKX RSS Robot Lincoln News 0 02-08-2007 05:41 AM
Concept to Production: '05 Lincoln Aviator to '07 Lincoln MKX RSS Robot Lincoln News 0 02-06-2007 03:22 AM
Concept to Production: '05 Lincoln Aviator to '07 Lincoln MKX RSS Robot Lincoln News 0 01-23-2007 07:20 PM
vB template by: CompleteGFX
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
All material on this is site is copyrighted by Lincolns Of Distinction Car Club INC. Reproduction by any means other than for personal use is strictly prohibited. Permission to use material on this site can be obtained by contacting the webmasters. Lincolns of Distinction™ is a trademark of this organization. Copyright 1999-2013, All Rights Reserved.
