Intro Jparry12
Jparry12
New here bought a mrk 8 3 years ago 2 ago had tranny rebuilt because there was a shudder it had low fluid added some works ok later on fwy Cruz on tranny slips outta OD into 3erd 3 times on the way there not back later went to pass a car tranny slammed into lower gear real hard tranny seemed ok shifting up and down a few months later did the same only this time parked overnite next morning tranny only had 1rst & 2nd slip in 3erd at 40 mpr so two years after tranny rebuild and out of warrant tranny does the exact same thing and I click OD off I get 1st 2nd and no third it stays in 2nd with higher speed with more pedal in OD its 1st 2nd spins in 3erd so I will like to know what my tranny swap options are and if there may be a accumilater piston problem or what with my tranny
94badbird
That was hard to read..
Is your trans cooler clogged maybe??
What year m8?
Can also 5speed swap..if it's a 98 the trans if pretty stout with the few upgrades they did to it, so if it's an older m8 put a 98 or newer 4r70 in it.
Jparry12
Do you know what I will have to do to make a 02 crown vic tranny to work in my 93 mark 8 4.6 it has an AODE in it now
I can't find the particular links at the moment but I think you will need to swap the internal harness, the TCC solenoid and re-pin the bulkhead connector. There's a lot of specific info over on the TCCoA site.
