My Jacobsen Turfcat Project
95blklsc
So on another thread I got into a conversation about my recent tractor project. I thought I would post up a few pics here. It isn't a Lincoln, but it has wheels and an engine!
This past spring I bought a house. Needless to say it has a very long driveway, about 1200' of pavement. I was able to pick up a Jacobsen Turfcat II that a local college had used for a while. It is a rear steering, hydrostatic drive and hydraulic PTO, 4 cylinder gas tractor. It had been sitting for a number of years, considering it's age it wasn't in bad shape, but it did need some attention. It came with a 6' cutting deck and a 52" snow blower.
This past summer I used it to cut the grass. It is a near zero turn mower, so it is surprising the tight spots I can get a 6' deck into. During the course of the summer I went through it mechanically to get it running well. I rebuilt the carb due to an accelerator pump leak. I completely took it apart, let it sit in chem dip, set it to factory setting and tuned it a little from there. I replaced all the fluids including the 5 gallons of hydraulic fluid. I also rebuilt the ignition, new rotor, cap, condenser, points, plugs, and wires. I also put a new battery in. It needed a lot of smaller things like a new fuel filter, new vac and fuel lines, new belts, etc. While all of these things sound simple, locating parts can be quite a challenge. The engine is a continental engine, but they actually bought it from Renault. I had to get most of the parts from the UK. Although I have been able to source quite a few NOS parts from ebay. Jacobsen parts are unbelievably expensive so finding other sources is pretty much a requirement if an individual owns a machine like this. Most of the time it is golf courses, businesses, and gov organizations that buy this sort of thing. You can easily spend over 50k on a new Jacobsen machine.
So on to the pictures. Go here for the full album, but most of the pics are in the thread
http://s192.beta.photobucket.com/user/rommayo/library/Jacobsen Turfcat II
Here it is with the snow blower on it before I started painting it this fall.
The snowblower was first.
There was more prep work done, then it was wiped down with acetone and a tack cloth was used to get the rest of the dust. John Deere enemel primer was used.
Gloss was sprayed in the second stage area as well as the chute. All spraying was done outside AWAY from the corvette!
First coat of john deere blitz black flat black paint
Here is it finished. I replaced all of the fasteners with stainless as well.
Next was disassembling and prepping the tractor.
Some primer
Some color
Adding mounts for a heat and electric switch panel
New lights, (6) 48 watt led flood lights, 2800+ lumens each
New seat
Canvas dyed
Lettering came in
Panel back together, stainless used on all bolts that were replaced
Roof and lights on
Let there be light!
I got a great deal on a new power broom from the manufacturer of the snowblower
I finished just in time for the snow. I started with the blower but the snow was so wet and heavy it clogged the chute after it started to rain. I switched to the broom and it worked perfect!
warden
Nice setup. When I first saw the yellow I figured you were turning it into a CAT. I really like that sweeper; Also surprised you didn't add a heated seat.
How far does that snowblower throw?
nice, i could use that vs my walk behind thrower when we get hit with a big storm.
I have a 130 stihl kombi that i want to get the PowerSweep attachment for the wet snow.
:thumbsup: nice vette, i miss mine. :frown:
95blklsc
The alternator is too small to put anything like that. It only has a 40A, although later models used a 50A that looks like it would fit. That was one reason for using LED lights. I only have to have about 300 watts of power to produce nearly 18,000 lumen.
It threw the wet heavy snow about 50 feet. I'm told it throws closer to 75+ with lighter snow. I'm going to be upgrading the distributor to one that a later model with the same engine uses. It has 23 hp with it's fixed timing distributor. A few years later they moved to a vacuum advance one that boosted it to 36 HP, otherwise the same carb, engine, drive train etc.
Get a sweeper, it is awesome. It gets it right down to pavement. Depending on the diameter they say it is pretty effective for reasonable amounts of snow. Mine is 2' in diameter and they rate it for 6" of snow at full speed, and it can handle more going slower. I would say 6-8 inches and it would be ok with the size I have. Make sure you have some sort of cab or cover because you WILL get covered with snow and sand/dirt. Having a windshield wiper and heater was pretty much a necessity for using the broom. The amount of crap that was on the windshield was crazy after just a few minutes.
You wouldn't believe how heavy that little machine is. Without the cab or accessory it is just under 1400 lbs. Most of the accessories are between 300-400 lbs, the cab is 1.5" square tubing and weighs about 200 lbs. So in total for that little machine you are looking at about a ton not including any weight that is added.
The stihl kombi is just a hand held small engine that has different attachments you can get. So no cab or cover. I wound up with the high power one by accident, the guy grabbed the one he had left and said it was the entry level pro size 90. But when he punched in the SN to register it it he said he made a mistake and it was the 130 but kept the price the same.
They have two sweeper attachments, one is rubber the other is a broom. Lots of people say the rubber one is great for clearing a few 1" of snow.
SCTBIRD1173
Mark my Bird!
Awesome little restoration project Eric! I'll have to check it out next time I'm there. Great job! :thumbsup:
95blklsc
ahhhhh ok I was thinking of something totally different. I don't see why that wouldn't do the trick for a sidewalk or something. Although I'd probably just opt for a shovel for only an inch or so of snow.
I have an attachment system too. I have the Echo one. I have a weed wacker, edger, brush cutter, hedge trimmer for the sides of the driveway, and a 3 foot extension. They have the same sweeper for mine too, but at $300 I didn't feel that it was worth it.
Yea, at $300 is why i have not got it yet, but people post reviews that it is good for up to 4" of wet snow and gets right down to the black top, can also use it for dirt, etc
http://www.youtube.com/watch?v=EOjEVWeBxpM
95blklsc
Awesome project!
Love it, nice house too.
Stihl kombi..... I need one no doubt. :cool:
Thanks!
You can't go wrong with a Stihl. I have all Echo stuff and they work excellent. I have their largest backpack leaf blower as well as a chainsaw and hedge trimmer. Granted I haven't had them long, but they work excellent.
BadSax
enjoys 3 martini lunches
Do you just not have enough things to do? :p
Too much time on your hands? :p
Also, and I say this with all seriousness... you are like the Jeremi of tractors...
it feels a lot longer... :D
Cobra intake huh...? :D
Also, I swear that is the seat from like a 1985 GMC Jimmy...
and what, please tell me what, the "radar" button is for? :D
95blklsc
Well, I'm always short on time, but this project needed to get done. I figure if I'm going to repaint and put some new lights on it why not spend a little more time and just do it up a little?
The seat is very likely from a early to mid 80's GM truck. It was NOS from that dealership I liquidated. I had it hanging around a while, I was going to toss it but never did. It just seemed to be a perfect fit for the tractor. It is really comfortable too!
The driveway may be longer that 1200', either way it is way out of the question to shovel.
Good eye's on the radar sticker, I was wondering if anyone would notice it. So that turns on the dual strobes on the roof. The switch panel is for a boat, so naturally it only came with marine themed stickers for naming the circuits. I figure it is on the roof, it help me avoid hitting people, close enough to radar!
So I just set the timing with a timing light, it was way off. It still jumps around a good bit. I have found an ignition system for a Renault (which this engine was also used in). It looks like a regular old distributer, but you can set the timing curve with software, upload it by USB, and have perfect timing that you can tweak. It's about $500...so maybe next year. It works well but with the snowblower you can never have enough power!
I forgot to say, don't insult Jeremi by comparing me to him. This is a hack job compared to what he does!
95blklsc
Up here we call those sweepers "sidewalk polishers" in the winter. :D
I'm sure our winters out here are a bit different than yours. While the broom would be useless on icy stuff, it worked great in the heavy wet crap we had. I'm not sure how it is in lighter stuff but I have the blower for that. I was hoping to be able to use it to get the driveway down to pavement after a storm to help prevent ice. Our driveway is in the shade most of the time and it has a small but long incline in a few areas, I can see having a hard time leaving if I let it freeze up. So far so good, but this is my first winter here so I'm sure I will learn a few things.
BadSax
Sounds like a good work out to me...
if I was into that sorta thing I suppose... :rolleyes:
Thank you... :D
and strobes you say... excellent :D
Fair enough :D
I just saw the photos. (they're blocked, at work..) that's a seriously impressive setup, and I'm quite envious of the dual-stage blower.
My "vintage" Deere doesn't even compare...
Very nice restoration, on hardware that clearly deserved it. That machine should serve you well.
Sierra3
Wow....somones been busy!
haha AWESOME Restore man!.
Love the updated interior and new seat. That snowblower unit will last LONG time now its all sealed up nice from the elements. Very nice. Did I see a RADAR button on that switch panel? ???? GPS? i assume its from a boat, but still cool pick for the job.
95blklsc
Joe saw the radar sticker too, it's for the orange strobes on the roof. Since it is a marine switch panel, there weren't a whole lot of naming stickers that came with it that fit what I need. Radar was the closest one haha.
95blklsc
Well, the heater was well worth the money. I figure for the heater assembly, hose, fitting etc it was about a $300 cost. Last night I was using the rotary broom to clear the light snow from the night before and I just left it on high the entire time. The past few times I've used it I only had it on high for a bit then had to turn it on low. The cab probably only got up to 50F or 60F last night but it was perfect. I just had a sweatshirt and I wasn't cold at all, well until I walked the garbage to the end of the driveway and felt how frigid it was (around 8F last night)!
