No Reverse Or Drive
chris2523
low fluid, no fluid, blown front pump, major internal leakage, broken input or output shaft, broken flywheel, broken drive shaft or half shaft, etc.
mag
I think I found the problem it seems the so called performance built transmission has a few issues. I will never buy a used trans again .Only 10k on it my a--
Is this the same one you recently purchased?
Jamesvinar
With the number of transmission issues ive had i think i can help. It would be odd for it to give out suddenly if it was low fluid or burnt clutches, thats usually slipping and then failure. If it was a broken shaft theres a good chance that you would hear something or it would still make the attempt to go into gear. I think theres a better chance of it being electrical or a selector issue
mag
I actually think it's the pump I pulled the return and there was a lack of pressure.
tonybrooklyn
Sorry for your troubles i had one for you out of my wrecked Mark. You contacted me once never heard back. So its long gone been in another mark since September. Guy drove it all the way to Arizona. He calls me once in a while to thank me. He says and i quote" Thanks bro its still chirping away" My point is used stuff is hard to buy people always get taken that's why i only buy from friends of friends. Best of luck hope it turns out better than the rear end scenario.
mag
Thank you for the kind words.You are absolutely correct hard lesson learned.
