My 97 wasn't lifting the car like it should be. We hooked up a Star II and got the 75 code for the relay.
Plugged in several used relays with no luck, commanded the compressor and solenoids on with the tester and started "jiggling" the harness. We were able to get it to work with the harness and relay "kinked" in a certain position. So I have a faulty plug going into my air compressor relay.
So my question is: What is the best way to fix it?
- Cut it off and solder in a new/used pig tail.
- Try to remove the pins from the connector (clean, crimp/re-install)
- Cut just the plug off and buy a new aftermarket plug and relay
I have the car at a good hight now with the air ride shut off, and I can just give it a bump again with the tester when she leaks down. Need a permanent fix though.
