M mag New member Feb 25, 2018 #1 Does anyone know the correct location for the 2 longer trans bolts that bolt the engine and trans. Last edited: Feb 25, 2018
J Jamesvinar New member Feb 25, 2018 #2 Should be the highest ones that you can access from the underside, when you removed the trans there should havr been 2 dowels that the bolts go in which might make it easier for you to identify them. The shorter bolts also wont thread into the holes
