THEMOJOMAN
How many miles before a tune up PLUGS & WIRES etc etc
My 94 had almost 150K on the original plugs and wires...they were said to be able to hit 100k before your first scheduled tune up.
My car ran awful before the swap... but there were plugs that had no electrodes or whatever the little hook things is called left on them...My '97 had about 125,000 when I changed the plugs for the first time. Nothing was wrong, I just felt it was time. My car did not run magically better afterward. but then again, it ran just fine beforehand..
The little hook things are called side electrodes.My car ran awful before the swap... but there were plugs that had no electrodes or whatever the little hook things is called left on them...
-J
Unless you want your car to run good.Wires should actually wait until failure...no sense in changing a functioning part.
Silly J...taking me out of context...Unless you want your car to run good.Performance wise that is.
I should see if I can buy them by the case.so does the auto parts guy scratch his head when you walk in and ask for 32 identical spark plugs?
No problem...I like to do that a lot...or pretend I do to make you mad Wayne.![]()
