88 LCS electrical ?
coolride88
Got a question for you guys, when I turn on the lights on my 88
LSC the fuel gauge goes to full and the tach jumps a couple hundred rpm's and freezes. Any ideas on what's the problem. This car only has 57K on it. Also does anyoe know how to reprogram the keyless entry, I didn't write the code down when I purchased.
oldschool1
Welcome back.
Got a question for you guys, when I turn on the lights on my 88 LSC the fuel gauge goes to full and the tach jumps a couple hundred rpm's and freezes. Any ideas on what's the problem.
[/div]
Normally, this is either a case of corroded contacts or a bad ground for our dashboards.
[/div]
The original code for your keyless entry is in the owner's manual and on the decklid, passenger's side, hinge, and on the keyless entry module under the package tray on the driver's side. Once you find the factory code, I'll tell you how to reprogram the keypad.
