91 air susoension problems
jumper
I am having problems with my air suspension I was in the process of the changing the alternator when I heard the compressor dump all the air out of all the bags. Now the car is down on the ground. I had the switch in the trunk off and didn’t jack up the car any, the battery was disconnected. Now the compressor just runs and doesn’t fill the bags. I did get looking around and you can hear the compressor run and then build up so tested the solenoids in the front and have no power to the solenoids.I checked for leaks with a squirtbottle mixed with soap. I even put my shop air to one of the air springs with the compressor on and still won’t fill up because of no power to the solenoid. no leaks anywhere???
