93luxurysnake
I put the 4r70w from a 98 f-150 in my car an now my speedo reads 70 when im running 60 how can i fix this?
which one should i use?... so i know what to rob one out of on my next junk yard endeavorprobably need to change the speedo gear.
O yes thank you driller your the man!!!!Study this... http://www.sccoa.com/faq/speedgr.html
There are 7 tooth and 8 tooth drive gears available in different variations of the 4R70W. It sounds like you possibly had an 7 tooth drive gear and now have a 8 tooth drive gear with the F150 trans? The 8 tooth drive gear would produce a 68.6 mph output at an actual 60 mph.
Pull the speed sensor and count the number of teeth on the speedo gear. Order a replacement with approximately 2 teeth less.
www.transmissioncenter.net
Yes I can see that:thumbsup:We made him President for a reason.
