Iv'e read the post in the maintenance section and it helped me understand the basics of the height adjustment system but I have some lingering questions.
1) When I pull out of my drive way and start off down the road, I can usually hear a slight "piff" noise, coming from the back of the car as soon as I hit about 14 mph. This noise sounds like an air bag venting, (like on a bagged low rider but much quieter) at first I thought it was just something sliding around in the trunk as I was told the airbag system is designed to be too quiet to actually hear the bags venting. However, I completely cleaned out all non-bolted down objects in the car and can still hear this, even with the air ride switch off.
2) My suspicions in the above statement is supported by the fact that even if the air ride switch is off for as much as two weeks of daily driving, the rear of the car will be sitting significantly lower than the front, but if the car is parked for that same period of time, there is nearly no difference in ride height, front or rear.
3) My mark VIII's compressor will run even if I don't exceed ~63 mph, in city driving every 5 minutes or so, for about 5-7 seconds, when I come to a stop. However I don't believe there is a leak, (lest not a significant one) because the cars ride height won't change after two weeks of not being driven.
Any ideas?
Thanx.
Any ideas?
Thanx.
