7 sek mark
im not rally sure where this should go but i guess its inside the truck so i put it here. some how im getting water into my trunk. my jack is rusting a wrench that got down in there is rusting and when i picked up my speaker box it had mildew on the bottom of it and on the carpet under the right (pass) side of the box. the trunk seal is sealing tight i can see the "dirty" line where it makes a god seal all the way around. the only other place i could see it leaking from is the rear window seal but mine is not THAT bad i did not think. any ideas where else to check for leaks?
also another trunk issue the spare tire cover is sagging so it makes it kinda hard to put stuff in the trunk. i was thinking about some 1/4" ply wood with a few 1x3" wood braces on the bottom and maybe trying to use the factory carpet to cover it with so it would still match. has anyone else ever had this prob? if so what did you use and how did you fix it?
