Gau8mechanic
I got the ball joint clunk in the front when I hit uneven surfaces. I checked them out with a dry park test and found the uppers bad. Replaced the upper control arms a couple months back. Still have the sound though. Lower ball joints looked fine. Radius arm bushings looked fine. Had my instructor take it for a ride and he says the upper strut hat could be bad on the fronts. Now I know on a conventional coil spring strut assembly, the upper hat can be replaced. I can't seem to find any repair info for replacing the upper hat on the air ride struts like we have. Is it a replaceable part or is this integral to the entire strut/bag assembly? I'm annoyed by this noise and don't want to find out I need to replace both front strut assemblies to make this better. Any thoughts?
