Anyone have a diagram for the fuse panels?
I need a diagram for the fuse panel under the hood on my '93 Mark 8. I need to know where the relay and fuse(s) for the ABS are.
Previous owner pulled the fuse for the ABS because "it killed the battery". I'm going to throw an $8 relay at it, replace the fuse, and see if that fixes the problem. If not, i'll remove the bulb from the indicator light.
thanks jp. I found where you postedvthe diagram for the inside panel by searching, but this one is what I was looking for. The car is now flat black and operational. Had three lights on the dash, abs, air bag, and ce. Air bag was probably a ground on a sensor which I think I fixed. Anti lock is sans fuse, and I hope a set of plugs will fix the ce light and smooth out the idle. New suspension holds air some nights but leaks down some nights. Rear shock mounts are fubared, it sounds like the suspension is falling out. I have a feeling I will be using a sawzall to change them and likely buying shocks as well.
Other than that she's cherry!
I drove it less than 20 miles since painting it and three people asked me "nice car, what color are you going to paint it?"
