i dont think i got your message unless you where asking about a blower as well. no you dont need a steering nuckle i designed them to fit around it. i will have pictures later to day or tomarrow. i recomend that when any one does the headers that they check or buy new engine mounts at the same time and steering nuckle. if they are bad you should change them while you are there. you need to extend you o2 harness and should change them as well if they are bad. you will also need new gaskets unless you want to use the old ones.
