93luxurysnake
I turn on my auto lights (daytime running lights) when you turn the knob to adjust the lights sensitivity they stay on all the time instead of turning off until you turn the auto fuction off any ideas what's wrong?
uhh.... I think you have the auto light function confused. It's not day time running lights, it automatically turns the lights on through the sensor on the dash once it gets dark. The "knob" you're turning is to change the lighting intensity but not for your headlights. It's for your dash lights, radio lighting etc. If you push it all the way up it should turn on all your interior lights.(if they work)I turn on my auto lights (daytime running lights) when you turn the knob to adjust the lights sensitivity they stay on all the time instead of turning off until you turn the auto fuction off any ideas what's wrong?
Not a problem. We ALL have those moments. :thumbsup:O ok thanx I never knew how that thing worked :lolgrin003:
no i did not im sayin that is the same beep it makes an all bulbs are good it only does it when you turn the key off not on like when a bulb is bad or outDid you take your check engine light bulb out?? lol
btw i dont have the auto light an the dimmer for the dash lights confused i know the difference i think the reason the dont work rite is they have not really been used for the life of the caruhh.... I think you have the auto light function confused. It's not day time running lights, it automatically turns the lights on through the sensor on the dash once it gets dark. The "knob" you're turning is to change the lighting intensity but not for your headlights. It's for your dash lights, radio lighting etc. If you push it all the way up it should turn on all your interior lights.(if they work)
no this is an entirely different chime than that one i have been told by a few people around here that it may be my ignition switch going badHmmm.... that almost sounds like it could be the key alert to let you know the key is still in the ignition once you've cut the car off and opened the door. Mine used to do that and then it quit. only time it beeps now is if the passenger door is open or if I left the lights on.
1st I never said you didn't know the difference. The way you described it was that you were turning the dial to try and change the intensity. I'm not sitting there with you and my advice was simply based off of what you posted and the information you gave. The auto light function is part of the headlight switch. The auto lights are either on or off. Simple enough. As far as the chime/beep you're talking about I suggest you either find someone near you to listen and help or upload a video of the recording so that we here can help. I've been around the cars plenty and I've only heard a few different beeps/chimes. So until you can provide some actual audio of the thing my thoughts and ideas are blind shots in the dark. :ttiwwp:btw i dont have the auto light an the dimmer for the dash lights confused i know the difference i think the reason the dont work rite is they have not really been used for the life of the car
that is exactly where its coming from but removing it will it disable my keyless entry mine is after marketOne last thing. You never said if you'd tried to locate the sound or not. Try locating it. If it sounds like it's coming from behind/in the dash but more towards the passenger side then pull the glove box and your culprit will be visible. The box back behind there is part of the anti-theft system(if i'm not mistaken, it's been awhile) I removed mine because it had gone bad and would make an awful chime every time I hit a bump, started the car, turned the car off etc. That's my last shot in the dark. If that's not it then I'm clueless without some kind of audio or visual help besides your descriptions.
Ah ok that makes sense now. I removed mine but it was the factory unit and I didn't have the key fob keyless entry, just the security pad on the door. The one I removed had developed an internal short, I'd hit a bump and it'd beep, hit the next bump and it'd stop. DROVE ME NUTS. I do have one in my old parts car if you can't locate another one and if it's the same. Just let me know.that is exactly where its coming from but removing it will it disable my keyless entry mine is after market
