BOOST! How much is too much?
JC
I've got a intercooled Vortech SQ pushing 8 pounds of boost into my Mark and I love it! I've never had a supercharged car before. However, I need more power (the story of my life). The engine is stock and has 90K miles. Would 10 pounds of boost cause engine problems? I have ART long tube headers and no cats.
mlschultz
Boost King
It all depends on the tuner if they are willing to push it that far. I have a Reichard Racing 3.1 pulley on mine and it hits 10 psi at 7150 RPM. Aric was able to get 401rwhp from my Vortech SQ/SC HO trim air to air intercooled, 05 GT blow through MAF, 60# injectors, SVT Focus fuel pump w/KB BAP. Stock bottom end w/ 108k on the clock.
Supercharged Lincoln Mark VIII Dyno Tune
Roadboss
On Work Release
Jack- it's time to join the rest of us and step up to the "full boogie". Get yourself that early retirement gift!! You know, the one you been holden back all those years for.
With Lonnie and Dennis down near you you should have no problems getting the answer to your question, it'll be just a case of how big a present you think you deserve. I just got a plain "gold watch" for myself while Mike is building a "fully jeweled diamond watch". LOL
logres
The block can handle anything you throw at it. It's the crank and rods that you have to worry about.
That being said, any boost that gets you up to around 450 rwhp is the max boost you can go with on a stock engine.
I think 8 psi has generally been accepted as the maximum recommended boost on a stock engine. You could likely tweak everything a bit closer to the edge but the tune would be the deciding factor.
Mad1stGen
Booster
Good tune and 12psi with 93 premium gas is what I've done and what I've witnessed done several times in the past.
High mileage motors, however , might have a problem with that ;)
Spinning that motor to 7k will do more damage than 12psi at lower RPM (i.e. smaller pulley)
mlschultz
Boost King
Yep, I think 12 psi on a high mileage completely stock motor might even be a little over the edge. Trust me when I say - I would have 12 psi on mine if it was considered safe by Aric. :)
Lonnie
Blue Oval Chips
450 on a stock bottom end is pushing it. I've seen even the most conservative tune still put a couple rods through the block.
maxmk8
I think a conservative # on a stock motor is considered right around 350-380 RWHP. Anything over 400 is asking for trouble.
logres
:confused:
Lonnie, I thought you told me that 450 rwhp is safe for a blown engine and 475 rwhp is safe for a turbo'd engine? Has some new info come out about these engines that I should know about?
Devin
Sean Hyland is pretty clear that you will probably have problems with a stock 4.6 Teksid block above 400 horsepower, with 450 being the absolute top limit. 400 is about as far as you can go and keep a good measure of reliability without going to forged internals.
If you swap out the internals for forged, then the limit raises to insane levels (1500 horsepower).
Everything that I have read says that 8 PSI is safe, 9 is pushing it, and 10+ is asking for trouble.
logres
Not doubting anyone here. It's just that I was told differently by other Mark VIII experts.
Devin
Well, Sean Hyland isn't actually a Mark VIII guy, he's a 4.6 liter guy, and he builds race motors so:
1) His experience is with the 4.6 line as a broad spectrum, not specifically the Mark VIII motor.
2) He builds racing engines which probably are put under a greater strain (max output) for a longer period than our daily drivers, and if one breaks it makes him look bad, so he undoubtedly overbuilds to keep that from happening.
3) Early "Teksid" 4.6s (93s and early 94s) were hand poured and hand cooled by Teksid themselves, and so I would expect they are stronger internally, which may be why one motor can handle more boost and another can't, yet both be in the hands of knowledgeable Mark VIII people.
All in all, it's YOUR motor and ultimately it's your decision. So if you boost the thing to 12 pounds and it holds together over an extended period, that's good on you. I only responded because you were asking what the safe boost limit is, and from what I read (not personal experience) 8 or 9 pounds with stock internals is pretty much it.
mlschultz
Boost King
I will say, a super charged Mark VIII is a hoot to own and drive. :) I enjoy, and appreciate the Mark much more than the Cobra Mustang I modeled my build after. Additionally, I am glad that I am replacing the stock Mark engine with a bored and stroked Cobra Teksid block, heads, and cams. Makes me feel better when going after more power. :)
robs
:confused:
Watch your converter too...
logres
I've got Lonnie's carbon fiber converter hooked up through his stage 3 transmission.
He practically dares me to TRY and break it...
My setup is also being used in a low 10 second Mustang that he knows about.
JC
Thanks for the feedback guys! Mine dynoed at 375 rwhp. I've got a 3000 stall converter and it's hard to launch without spinning the tires. It's a waste of time to go to the track until I get slicks. It spins the tires and fishtails badly. No fun there.
BlackMark8
I just think its crazy that you can have a supercharged mark viii with 400+ RWHP and driller has a naturally aspirated car with 250 RWHP and run a low to mid 13's. When the supercharger just barely gets you into 12's .
And who is that guy with that black 98 lsc with that big vortec and runs low 11's. Is that guy a member of LOD ?
Devin
Driller is doing an excellent job of putting power to the ground. SO much time can be gained/lost in the first 60 feet, and he is obviously the king of the small end of the track.
On top of that, it takes more and more and more power for each 1/10th you take off. Drag racing is so much more than just mashing your foot to the floor and holding on.
