Can you help us wire a kill switch for our 1994 Mark VIII Lemons project
phyveaux
All, we are closing in on the finishing touches for our 24 Hours of Lemons 1994 Mark VIII. We need to wire our kill switch. We will be wiring according to the recommended directions below from the Lemons forums. We have a 4 post kill switch. Two large posts will interrupt the battery. Two small posts need to interrupt the hot lead going into the ignition. Unfortunately, I don't know which wire this is. There are 3 or 4 hot wires when you use a volt meter to test. One of these is the hot going in, probably the others are the starter, accessory etc. as mentioned below.
LOD won't let me upload picture, because it says I've exceeded my quota? Pic of the pins and the harness are at:
https://drive.google.com/open?id=0B58DltRFzCOvbjgzaE9RTEtCTFk
https://drive.google.com/open?id=0B58DltRFzCOvRWp1OEtnNHJpQ1U
Can anyone look at the pins and let me know which one is 12V hot in? This is the one I want to interrupt from the battery. The picture shows the labels (A1, B1) etc. If I can know which one is 12V in, I can figure out the matching wire. I thought I had a good spreadsheet with this info from an alarm installation site, but it isn't detailed enough. Any help would be very appreciated.
These are the instructions from Lemons Forums:
This is how I have wired at least 4 different cars without ever killing an alternator using (mostly) the factory wiring harness and always in compliance with LeMons technical regs. IMHO, YMMV, associated disclaimers apply.
0. Remove the negative wire from the battery. Don't electrocute yourself.
1. Get a 4-post kill switch. I like the Longacre waterproof, since it always seems to rain sometimes at a Lemons race, but there are others out there. Mount it somewhere that (a) your drivers can reach when belted in, (2) that a corner worker or EMS can reach from outside the car and (3) where you can remove it easily because it's easier to attach cables to the back of it when it's not mounted.
2. Figure out the factory ignition circuit. Most cars have one hot lead to the ignition and then a couple of hot outs: one that goes to the starter circuit, one to the run circuit, one to the acc. circuit. You only care about the hot power going in. Cut that line somewhere convenient, giving yourself plenty of wire on both sides. You now have two cut ends. Connect one of those new ends to a new wire that you run to one of the small posts on the kill switch. Repeat from the other small post to the other cut end. I suggest using crimp connections and not wire nuts, but it's your life. This is the connection that will kill the ignition just like the factory does, and using the factory-figured-out method for not nuking alternators.
3. Find the thick + lead from the battery to the engine. Splice that with new wire to the larger kill switch posts in a similar fashion to the instructions in paragraph 3. This is the connection that will kill ALL POWER in compliance with Lemons technical regulations.
4. Re-connect the negative battery lead.
5. Test.
6. Rejoice, or alternatively, despair and try again until you reach joy.
According to the '93 EVTM, B1 through B5 are all 12V from the battery.
B1 and B4 are (Y)Yellow from a 40A engine compartment fuse. I believe interrupting this circuit will kill the ignition. If true, you will want to cut it before the splice which leads to B1 and B4.
B2, B3 and B5 are (B/O)Black with Orange stripe from a 50A engine compartment fuse.
phyveaux
driller,
Thanks for the quick reply! To clarify (because you listed B1 and B4) in both lines.
Should your second sentence read, "B2, B3 and B5 are (B/O)Black with Orange stripe from a 50A engine compartment fuse."
That does make some sense because the alarm site information said the hot ignition was "yellow". Because there were multiple yellows, (and multiple black and orange) we got confused. I really appreciate that you answered so quickly. Haven't gone back to the car to locate the fuse running B1 and B4. Theoretically, the running engine should die when pulled. If it does, it interrupts the car exactly the way Lemons wants. We will report back our success. Thanks again!
Also for those who have expressed interest in the project. Pics of roll cage, seat and new black paint will be uploaded soon. New tires arrived on Friday, being mounted on chrome rims from a 2003 LS (car currently wearing the worst aftermarket rims I've ever seen).
Correct, I edited my original post above.
There should be two Yellow wires, one on B1 and the other on B4. They originate from a single Yellow wire at a factory splice which should be in the wrapped harness going to the ignition switch according to the EVTM. Follow the two Yellow wires back and you should be able to locate the splice.
phyveaux
All right, so just for everyone, this is actually backward from what was expected. Pulling the 40A yellow wire fuse left the engine to run. Pulling the 50A black and orange fuse kills the ignition and kills the engine. That makes sense from the 94 manual which says the 50A runs the B2,3,5 pins labeled as ignition in the manual. There is one black and orange that runs through the firewall and then splits into three about 6" from the ignition switch. Thanks driller for pointing out to cut it before the split to three - that's going to work out perfectly since it's all right there. LOD and driller made this project easier than we expected!!!
