Can't find the Self Test Input (STI) wire
ovysimac
Hello all,
Need your help in finding the STI wire on my 93 M8 base, stock (Gen 1). I developed a CEL and need to scan for trouble codes. I need to go the old school route and use the CEL or a voltmeter/test light to scan for stored code(s). In order to do so I need to short this STI to pin 2 of the self-test connector (STC).
Problem is I can't find this one-wire STI (I'm told that it is white and has a connector resembling the telephone connector). I looked high and low, to no avail.
Questions:
1. Does the 1993 Mark 8 have this STI white wire?
2. If yes, where in the world is it located? A pic would help.
3. Is this STI wire needed (besides the STC) when usind an OBD-I scanner?
Thanks for your help.
ovysimac
Looked under the wide black cover to expose all the wires leading to this SDC TEST port but couldn't find this STI wire, nor any sign that it was cut/removed...
Are you sure you’re not confusing it with the suspension test port?
It’s been a long time since my ‘93 was EEC-IV, but I remember it being under the shock tower cover on the drivers side? The test port for the suspension is on the passenger side.
ovysimac
That's EXACTLY where it was! Thanks for pointing that out to me.
Best wishes!
- - - Updated - - -
Thank you.
BlackIceLSC
You're quite welcome. For years I would take some of my random photos and draw/label them and save them....I always hoped some day they'd become useful. Now some 14 years later, they still are.
