Car reves up and down at idle
Rich00033
Do you know of the iac being bad would cause a loss of power when the motor is warmed up and would I make it die at red lights with the a/c running??
mag
Pull codes before changing parts [ It's called a Idle Air Control Valve think about it) It allows the ECU to maintain minimum RPM irrespective in engine load it is sometimes called a anti stall feature
My 98 does this, but only once, as it is warming up. I only notice it at a stop. If the car doesn't stop during warm up, nothing happens.
It's like someone is revving the engine a little. I put it in neutral, rev it up a little myself, and it's fine again.
I replaced the IAC but it still happens. I was thinking my problem might be the throttle position sensor, but the vacuum sounds like an easy place to start.:D
Rich00033
That is exactly what mine is doing to if you don't cut if off after it warms up it don't do that crap but if it's warmed up and you start it up it starts acting up I just put a new iac valve on mine and it still does it but it did get better and I'm about to do the tps and see if that helps
Rich00033
And keep in mind I am not throwing any codes at all when this happens so I can't pull codes that ain't there
Rich00033
And if it was a vacuum leak it would do it all the time I would think not only when it warms up and you cut the car off and start it back up then it starts leaking vacuum that makes zero since
chris2523
nah. cold start up maps are rich.
lean it out when it warms up and the problem appears.
btdt.
